1 - 10 of 10 Posts
So I got this bike for 400 bucks because it doesn't shift right. I unloaded it into the garage and did some serious massaging of the gear shift to find neutral. That consisted of pushing the shifter in, turning it a certain way, pulling the shifter back out and doing a very risky game of twister; holding the shifter on the verge of a shift and wiggling the bike back and forth.
Anyways... I took the right side cover off to peak inside, and to my dismay the shift shafts were not aligned. There was a bigger problem here though... they weren't even aligned side to side. So I started pulling on things and managed to get the b side out carefully by twisting it out and around the the opening there and the oil pickup tube.
There was no teeth on the shaft though! The whole arm was missing. It looked like it had been hanging on by one tac weld the whole time. When I looked inside the gearbox before, it was there but not aligned. I'm guessing this thing had bent in the past and that's why it took some sweet sweet tender motivation to get it to shift in the first place, and me yanking on the shaft sealed the deal.
I found a listing on ebay for a 1987 vt700c B side shift shaft, but the end doesn't look anything like I have here.
294167
Here is the ebay listing:
Even worse is I can't find that arm anywhere down there in the oil. Ill have to get a decent magnet to try and fish it out.
So my question is, does this replacement look like it should work? Or was mine not the correct one in the first place? I thought the side B on these 700s have 3 teeth, and mesh with side A's 2 teeth. I'm just fairly confused
Discussion Starter · #2 ·
I could have taken a clearer picture to show this, but underneath the arm is splined. There is a sleeve over the spline with a weld on it that looks like it broke. However on the ebay listed shaft, it looks as if that arm is completely welded in place instead of press-fit
could easily be a new rendition of the part your after. possibly for the intention of correcting the issue you found. i cant be of much help outside of that tho but parts to get changed without notice after production. the one thing you can look at is obviously that part is probably discontinued however there might still be notes in the parts breakdown about a change in that part.
2001 Valkyrie I/S
According to the parts breakdown the 84 and 87 are different part numbers.
Well that would really suck. It might be quite a search to get the part. I still have some other things that need to be tied up anyways while I wait. I'll keep it updated for the few that are interested
Could you have the piece welded back on?
It looks like the one on the 1986-87 is supposed to be solid.
The early one looks like it is on a spline.--???
if you can find the other piece and its not mangled so proper position can be figured out any decent metal fabrication shop could put the the splined sleeve back together.
Discussion Starter · #8 ·
So I received the part that fits on the 87, it didn't work. It's almost as if the paw wasn't even long enough to touch the side a paw. It fit nicely in there and the shift plate lined right up, but didn't have the reach to be actuated by the shift lever. So back to the drawing board. I still can't find the broken piece, somehow it's really missing in there which is worrying me. I've been short on time lately or else this would be done very soon
'83 VT750C
Definitely take the time to SCOUR the engine for that part. It’s hard to tell from the diagrams, but they could have changed the lengths of the two shafts. So you could try an ‘87 shifter shaft if you can find one cheap, just to see. Your original should definitely have the teeth on it. My original ‘83 bike one looks fine, my parts bike one was definitely welded at some point in the past.
Here is the ebay listing: View attachment 294168
I have an "85 and that ebay one looks just like mine. I think you will be fine with that one.
1 - 10 of 10 Posts
