1 - 6 of 6 Posts
Remove left engine cover, unbolt stater winding assembly, reinstall in reverse order.
But did you look at the 3 yellow wire connector from the stater, that many times overheats and melts connections?
Discussion Starter · #3 ·
What happens if the 3 yellow connectors melted?
It can cause a short or increased resistance. Either way it prevents the current from getting to the rectifier. It's a common problem. Some people just cut out the melted portion and solder them together. It's 3 phase so the order doesn't matter.
It causes an open circuit in 1 or more of the 3 phases. Just like unplugging it, so no charge.
84 VT500C retro bobber
The strength of the magnet on the stator will make it feel as though it won't come apart, but it will. It's a fairly straightforward job.
1 - 6 of 6 Posts
