21 - 23 of 23 Posts
I've got the brakes working I never even realized there was alignment marks I had put it on way off and it's average 65° around here
Don't let missing the alignment marks get you down. I've owned and been wrenching Shadows since 2002 or earlier, perhaps 2000. I've known about these marks probably 2 or 3 years myself, and then only for certain about the front one since a few days back when I took the camera out mid-message to check on it (although since the brakes were in alignment, I probably did spot it last time I had that bit off, though I could also have fluked it). Now that we're talking about it, I do remember some years back struggling to get all the bits into an alignment that gave me room on the adjustor and a comfortable pedal position, while also having the brakes work without too much travel. While memory says it was half an hour or more of extreme frustration, it was probably only 5 minutes, but it was annoying getting them right. Those alignment marks should have big flashing neon indicators or something!
At 65°F your bike should start happily without choke.
'83 VT750C
It was an affliction of some of the early Shadows. Some were just notoriously hard to start 'cold', even at temperatures of 18°C and above! My father was amazed when he met someone with the same bike as his that started almost immediately on a cool morning. This was straight from the dealership, with no adjustments whatsoever.
Nice to know, and hopefully I will remember it if I need it :)
My 86's normally start at that temp and a bit lower fairly quickly if the battery is really good, but they do suffer a problem with the electronic ignition - cranking the engine doesn't always leave enough for running the electronics. In that case I try to let go of the starter just at the right point, and do shorter runs with the starter as well (let it crank a couple of times then stop). Hot water poured over the battery can help a surprising amount!
21 - 23 of 23 Posts
