So, first and foremost, there is still no conversion kit for converting the Honda Shadow VT1100CG from shaft-driven to chain-driven. My hopes for this discussion is to brainstorm with other shadow enthusiasts in order to custom build the parts required to convert a 1986 Honda Shadow VT1100CG from the stock shaft driven final gear to a custom chain driven final gear. I've been playing around with the idea quite a bit for some months now and finally found someone who's crazy enough, like me, to actually CNC me a forward sprocket for my 1100. I know as it stands right now, the VT600 ACE and the VT750 ACE are the only chain driven Shadows to my knowledge and I just don't like that. So, I'm gonna make my own conversion kit for the 1100's. I figure the swingarm off a '86 VT750 ACE should line up with fitment just beautifully to an '86 1100. However, I don't feel like buying a used 750 swingarm and find out. If I need to custom make a swingarm then so be it, but the only real issues I'm coming across is gearing. Assuming that all my fitment is easy and lines up, I now run into the issue of the bike being set up for a shaft final drive compared to the chain final drive, and maybe compression but I think the compression should be good. Correct me if I'm wrong but there shouldn't be any difference between shaft driven bikes and chain driven bikes. So gear heads, I'm all ears, I want all your options, thoughts, concerns -- anything and everything that gets me to that chain drive conversion I want.
