I'm having issues warming up my '86 VT500. It will start right up but I have to let it warm up for 5 to 10 minutes before I can ride it. If I try to give it any gas before it's warmed up, it will die. Once it's warmed up, there's a slight flat spot/hesitation as your first turn the throttle but then it's fine as you continue with more throttle. Other than that it runs fine. So it's just when it's cold.
I left it out one winter and the fuel gummed up everything and so I had all the carbs and fuel system cleaned out but it still has the warming up issue. Unfortunately with 2 little girls at home I'm going to sell it
So if it's an easy fix, I'll try to fix it. If not, I'll just sell it as is and hopefully I can find a buyer who can fix it.
thanks for any help.
