1 - 5 of 5 Posts
Ok so here we go. I had a 97 Honda VLX given to me that a guy started to hard tail and build a bobber. So when whoever hard tailed it they didn't put the spacers and all the parts back on the swing arm pivot pin. So at the point where the swing arm would attach to the frame its not in the center or spaced like it should be. So im going to cut the bars he welded in for the hard tail so that i can properly center swing arm and redo the hard tail.
But im having issues finding a clear diagram of what the placement and spacer size and parts list for the swing arm pivot pin is. So basically i need help knowing the swing arm pivot pin assembly and what goes where so that the swing arm sits in the correct location to hard tail it again.
Thanks
2007 VT750DC Spirit “chopper”
Discussion Starter #5
Ok that helps. Does the motor have anything to do with the swing arm position as far as being centered or in the right place?
1 - 5 of 5 Posts
