1 - 3 of 3 Posts
Has anyone ever tried putting baffles back into the stock pipes? I can find an amazing amount of info on taking them out but nothing on putting them back in. I would like to quiet mine down a bit as I drive to work at 4am and don't like the idea of becoming unpopular with my neighbors. Thanks for any reply
Problem with putting them back into stock pipes is that they have to be welded in. Also they are usually destroyed in the removal process. So with stock pipes its basically a one way operation, most times. If you take them out clean enough they can be put back and tack welded in place. Easiest option is to just replace the mufflers, with a set of slip-ons.
I know from experience be careful welding them back in....chrome discolors easily...
1 - 3 of 3 Posts
