1 - 18 of 18 Posts
2000 Shado Ace 750 14k: Woke up to small coolant leak coming from the waterpipe seal. Looking at the CLYMER repair man looks like a loosen slide replace seal operation. God I hope im right otherwise its in a hell of a spot. have you replaced these seals ? HELP. Btw are these a auto parts house item or Honda specific dealer/mail order item.
1998 750 ACE
IF you`re talkin` about the "crossover tube" it ain`t too bad of project of 45 minutes...
I THINK there`s a sticky on it too...
Very easy to do. Just need to remove the "Faux" fins on the tip of the heads and get yourself some long needle nose pliers and some dental floss and vaseline. And of course the new gaskets.
Cant I losen the clamps slide for and aft and replace said o rings ? Wen reinstalling is vaseline needed ? Is there a thread with pictures ?
There's a thread for the 1100s in the sticky section at the top of the technical discussion page. I don't know how similar the 750s are though. Its a pretty easy job with some nice long needle nose pliers and some fishing line. Didn't take too long at all.
Discussion Starter · #8 ·
I just saw a great how to video on Youtube tried but couldnt upload. Under: Dennis Coffey Honda Shadow VT750 water pipe crossover etc. 24 min long looks very dooable imo all for +/- 15$. Definately gona try. Found out its pretty comon, one of the coments said the dealer wanted 600$ for this job ,sounds exessive then again theres no such thing at a dealership.
1998 750 ACE
$600 Honda Buck$???
LLLL Bring it over, I`ll show you how to, for nothing!!!
Of course, you can leave a donation, if you feel so moved...
The 2000 is the same Bike as mine...
I did NOT have any issue with removing both clips, sliding the tube forward to install the rear "O ring" then sliding it rearward to install the front....
Lubrication was helpful in sliding the tube with new "O rings" though...
I made ""Special tool # 321678"" for installing the "O rings" onto the tube...
It consisted of two pieces of small gauge wire hooks, long enough to grab and maneuver the "O rings" into position...
Including Getting the bike onto the lift, reading the sticky and fabricating ""Special tool #321678"" = 45 minutes TOPS!
Discussion Starter · #10 ·
$600 Honda Buck$???
Do you remember the size of the o rings , can i pikum up at the hardware store or autozone ?
Discussion Starter · #11 ·
Success !! Fixed it just like the video mentioned above on youtube, not to bad 2$ worth of 16mm orings x2. Gona ride it this w.e check it out if everything is copa ill refill with correct amount of antifreeze.
1998 750 ACE
borings -= Probably got fumble thumbs like me...
Glad you got it fixed, even without my reply to your size question...
but to answer > Nope, I bought `em from Honda and didn`t worry about it...
Lets RIDE
Discussion Starter · #16 ·
Zzzzzzzzz.
Boring Oring its all the same haha. Orings came from local Ace hardware. Havent real world drive tested it yet (****** weather) but plan to Sat. So far start up idle drive up n down to corner have all been leak free where as before it leaked right at start up so Ill assume all is well. If not Ill report.
Yeah it darn incorrect that made it look like boring instead of oring. Yeah and looks like I will be having to does to the wife's 02 vt750dc spirit. It only seems to leak after it has sat for a bit and leak just enough to make 4" circle on the ground and then stop. So it looks like I will be doing this sooner than I thought, and I might as well do it on my 02 sabre at same time so I don't have to worry about it later
Discussion Starter · #18 ·
Good idea, I deviated from the istruc video a little in that I did move the man choke out the way but I used a long pair 18" of needle nose and a small 90° gun cleaning pick to hold and stretch the ring with the pick or push it around back and over the water pipe insted of the dental floss. Cause I didnt have none.
1 - 18 of 18 Posts
