1 - 8 of 8 Posts
Should the Trickle charger be hooked up to the battery the whole winter or just once a week for several hours ? suggestions anyone.
Proper procedure for trickle charging battery?
If you use a battery tender or maintainer leave on for the whole winter a trickle charger will ruin your battery if left on
Get a mainter or automatic charger, WITH a trickle setting, and hook up all year. If you are using a manual trickle charger, I would only run it periodically. Over charging is just as bad as undercharging.
I bought this one for my '86 VT1100. Plug it in every night and leave it until I want to ride. Shuts off by itself, no need to unplug. EASY install.
Just $23..
1 - 8 of 8 Posts
