I've been having elec problems for a month but I thought I had it solved. Replaced the R/R and the connector. It ran great for a week. Then, it started missing. Battery is full charge. I suspected maybe the fuel filter or bad fuel. Changed the filter and it still misses. Drained the fuel, pulled the fuel valve assembly out of the tank to see if there was some kind of screen. Nothing obstructing. Put the valve unit back on the tank, filled the tank with good gas and now, it starts perfect as usual but when I put it in gear, it immediately dies even with the clutch in. ???????? HELP!
