Ill double check but I beleive one of the two was closed with some metal piece, looked like part of the internals to me. So i take it both holes should be opened ? Ill take some pics,.
Ill double check but I beleive one of the two was closed with some metal piece, looked like part of the internals to me. So i take it both holes should be opened ? Ill take some pics,.If there is a layer of mud on the bottom of the master, clean it out with brake clean and see if you can inspect the very small hole. Also the larger hole supplies fluid to pump.They have to be clear.
Where exactly is the circlip and how do i release ?The larger hole supplies fluid to the piston and the small one is called a compensation port to allow the fluid under pressure to release pressure when you let off the brake, or it will stay pressurized and the brakes will drag.
If you actually see metal you had better rebuild or replace the cylinder. There are only 4 or 5 parts and it should be easy to inspect. Release the circlip and the piston will slide out.
Wont da boot tear ?Take the lever off and pull the rubber boot out and you will see the small clip and pry it out to release the piston.
I pulled the boot out. But the clip is a real beeatch, im stuck on it.Put some WD40 on it and pry it gently with a small screwdriver on the edges. It may be old and cracked already.
That's not weird, Cisco. That's what happens when you get something right.Story just got weird. Remember im not a mechanic, so this pm i essentialy redid everything i did yesterday exept now a get a nice good squirt out the bleeder nut. So i bled them and im way better than when i first rode it id say its up to 70-80% capacity. Rideable anyway. Thanks guys. Btw i still plan on taking it to get a safety check soon as i get the title transfered.
