1 - 11 of 11 Posts
On my 83 vt750 if I apply the foot brake OR hand brake, all the lights dim. This suggests there's a short somewhere. I tried using a different "stop sensor" box (from my parts bike) that sits under the air filter box because I thought maybe that thing had gone bad, but still the same result. I guess they both could be bad. Does anyone know how to test the stop sensor?
All other electronics still work fine. The only thing I've changed electronically is adding a ground wire to the metal plate on the bottom of the fuel pump because there must be a loose ground connection and it wasn't always pumping when it should have been. I don't think this should be related to the brake light but who knows.
I guess the light bulb could be bad but I don't understand how that would create a short and pull so much current that all the lights dim.
thanks
Super Moderator
Well definitely not the bulb. I guess it's time to bust out the wiring schematic and try to track down the problem. Any other thoughts?
Maybe a bad ground? I know on trailer lighting; if you have a bad ground to the trailer, when you use a turn signal, the opposite signal dims when the other side is lit.
Just a thought,
Phil
Remember, the 83 has "tail light" idiot light...in instrument panel. Check that circuit for short as well.
IDK, water in light bulb?
Discussion Starter · #9 ·
Yeah, so is the idiot light supposed to light up when the tail light is NOT working, and is it affected by the brake light circuit?
Also I'm leaning towards a bad ground somewhere too. Still searching....
I wish the wiring diagram was in color. I'm thinking about photo-shopping it in color. I'll post it if I ever follow through with that idea.
Discussion Starter · #11 ·
UPDATE:
I hate when people don't update their own thread with the solution they came to. Well mine turns out not really be a "solution" but a good story about a dumb a*s. So it turns out that I had accidentally swapped the fuel pump wires with the front brake light wires. This in turn did something bad to the fuel pump relay thing because it was getting a bit hot. Luckily I had another relay I took off my parts bike. In the process of things I checked the indicator box and the taillight failure box and they both worked fine. I also found the brake lever switch up at the handlebar had broken and I again had a spare part I could use. So now everything works. I still however, notice a very slight dimming of lights when the blinker flashes or the brake light comes on. More so when I have my brights on so I think there is probably still a weak ground somewhere, but I'll worry about that later (last famous words).
1 - 11 of 11 Posts
