1 - 4 of 4 Posts
Hey all,
If I remove the brake resevoir cap to replace it with a new fancy one, do I need to prime the brake system once the new one is install?
Or should it be a simple swap out?
Tips/Tricks??
Thanks
O
I just swapped mine for one of those purty ones this afternoon. I removed the two screws and just lifted the old cap off. There's a plastic cover/gasket under the metal cap. Just press the new cover on and re install the screws.
O,
It's just a simple swap (unless you empty the resevoir). DON'T squeeze the brake handle with the cap off, or else you'll make a mess. Oh, brake fluid ruins paint, so be careful taking the resevoir cap off (cover your tank and fender with a sheet of plastic.
Jim
2001 Spirit 1100
1 - 4 of 4 Posts
