thanks @CSRoad I'll try to scrounge a pair of those, I've only got godzilla sized vice grips and pocket sized but no needlenoseBrass does that sort of thing if the screw driver is not just right.
Since you will be replacing it anyway.
I'd hit the small screw extractor in the drill as the last resort, but first I'd try my little needle nose vise grips on the meaty part of the jet, they usually win.
I love these fish eyed vice grips!Brass does that sort of thing if the screw driver is not just right.
you need Vampliers, probably the small size, the tips are concave for gripping screw headsthanks @CSRoad I'll try to scrounge a pair of those, I've only got godzilla sized vice grips and pocket sized but no needlenose
Be careful with a torch, IIRC the carb body melts at about 700 degrees Fahrenheit.Get a pin point mini torch and heat the metal the jet screws into.
