1 - 2 of 2 Posts
Oops, sorry, my question was, how do I check to see if the cam/crank sensor is bad on a VT 600 97' I cannot get it to crank and have gone over all the basiscs?
I don't know the color of the wires on your bike for the crank position sensor. (There is no cam sensor).
But in any case the sensor is just a coil of wire with two leads. If you connect an ohmmeter to it, it should read about 400 ohms. However, pretty much any number between 200 and 1000 means that it's okay.
--Justin
1 - 2 of 2 Posts
