As some may know I recently got my carbs rebuild by TJ brutal customs... Long story short... I've manage to get the bike to idle (low idle from the sound) but at the smallest turn of the throttle it dies.
Now I've change the spark plugs, battery, petcock screen and cleaned the tank, change the fuel filte and changed the fuel pump.
Something tells me I'm not getting enough fuel, I've heard that some people should test the pump to see what kind of pressure the pump is putting out. Would you guys start there? I'm at a loss.
I've sprayed carb cleaner around the boots to see if I'm leaking air, that's a negative to.
Meanwhile a friend was over and saw my tank had some rust in it but lucky for me his father works for a shop that seals them and he's hooking me up with an acid wash and seal Job.
Any advise is sure welcomed.
