I'll start by listing the mods that were on the the bike before winter. It had a k&n filter, hard krome piped w/o baffles, dynojet kit.
Over the winter I kept the pipes, installed TJ Brutal Customs Velocity stacks, 4 degree timing mod, clutch Springs, and bought the Tj Brutal Customs jet kit.
I have tried many different combos with the jets, but I keep getting different degrees of the same issue.
The issue is, I sputter and have absolutely no power. It's as if I'm hitting the Rev limiter as soon as I leave the driveway. It idles a little rough as well. I have 145 pilot, 45 main, and dynojet needle on the 4th groove. This combination worked for about a week, and ran great. Then the sputtering started. I should add that I get some black smoke briefly while revving at idle, but no popping or any bucking/sputtering at idle. It only happens under load.
I haven't replaced the plugs, not sure if the P/O did or not. I have 11k on it. The plugs were a little wet and had a little bit of brownish gunk on them.
I've read these are symptoms of running rich. I moved the needle up a clip and it was even worse. I had to Rev almost to realize to keep it from drying.
Any ideas? Do I need to simply replace the plugs? Did I bump the floats out of adjustment? Electrical issue? It's definitely getting enough air, so I know it's a gas or spark issue.
Thanks for your time.
