1 - 2 of 2 Posts
Hi can a 750 carb fit on a 700 ? I have an 85 shadow 700 and I was just wondering if a 750 will fit
They might bolt right up to the cylinders but they are different model no's and have different size main jets. I believe they are both 36mm carbs. You could probably make them work with tweaking as the rest of the connections (boots, cables, enricheners, hoses) should be the same. Again I can't say from experience.
1 - 2 of 2 Posts
