1 - 11 of 11 Posts
Guys,,on my 04 aero 750 shadow ,, I have some bad gas :x... got it from a station that was low on gas ,,the bike was running ok until I gased up ..I have drain the tank ,,I need to drain the bold,with the drain screw ,,Can I get to the drain screw with having to take the tank off the bike ,,,should I be able to see the screw from the left side ..
Thanks for any help....oh I have ran seeforn and that did not help ,,,the olny way I can keep the bike running is to pull out the choke ..
Discussion Starter #5
come on guys --I know some of your have been thur this and talked about it on here ,,,,Its ride time ,,weather is so pretty here ,,80 today .
These bikes have a pretty standard carb. The drain screw (one on each carb) is located at the very bottom of the float bowl. the bowl will have a small nipple on it, and just above that is the drain screw. Loosen it 2 turns, wait for the fuel to stop flowing from the nipple, and then gently seat it again. best to put a small catch-can under it. They don't hold much, but you don't want it to puddle on your bike.
--Justin
The Aero 750 is a single carb bike. Try running some isopropyl alcohol (6 ounces should do it) in with some fresh gas (GOOD gas), take her out for a hard ride and it should get rid of the water. Make sure you drain your tank of the crappy gas first, obviously.
Oh, right! Aero! (duh!)
Well, in that case, the job got twice as easy!
--Justin
1 - 11 of 11 Posts
