1 - 4 of 4 Posts
I got a set of custom mini bullets to replace my rear turn signals but my stock turn signals have a oval shaped rubber stoper with two holes (one for the bolt one for the wires) that they mount to. The mini bullets have a single stud with the wire though the middle so there will be an extra hole left. WHat should I use to cover the stock mounting holes?
What I want to do is change the rear turn signal from a 19" width to a 17" width like the front. I think taking 1" in off of each rear turn signal will look more unform with the style of the bike. I will do it eventually.
What should I use to cover the stock mounting holes?
Would some black rubber plugs or some chrome bolts from the hardware store do the trick?
Check and see if you have a ACE hardware.. You should be able to since some stainless whole caps in the yellow trays.
My local ace hardware has a Metric chrome set of bins also.
1 - 4 of 4 Posts
