1 - 4 of 4 Posts
Is there a way to adjust the tension on the choke cable on my 03 ACE 750? The cable pulls itself in as the bike is idling and I have to pull it back out to keep it at a high idle rpm.
Dee & Red,
All you need do is to tighten up the black plastic nut behind the choke knob. It will squeeze a little tighter on the choke knob shaft and hold the choke on for as long as you want it to. This is a plastic nut, so don't overtighten it - it doesn't take much to make a big difference. Try turning it 1/4 turn or less and check the operation.
Brian
Discussion Starter · #4 ·
Thanks Brian. I'll look at that soon but it's in the high twenties with a 25 MPH breeze here today so I'm in no rush. :cry:
1 - 4 of 4 Posts
