I just bought my 2005 Shadow Sabre 1100, can I clean the air filter or must it be replaced?
I'd recommend replacing the stock air filter since it's 10 yrs old. Miles is what matters and what kind of conditions to sand and air pollutants that would cause constrictions. I replaced my newly purchased 96 Shadow's original air filter with only 8,600 miles on it because it looked dirty in spots. Honda does state that you can use an air compressor to lightly clean the filter. But I chose to replace mine with the same OEM rated paper filament from JC Whitney so I could start out brand new.I just bought my 2005 Shadow Sabre 1100, can I clean the air filter or must it be replaced?
Not the stock filters.Does the filter need to be oiled?
In a pinch, brake parts cleaner will clean a paper element filter just fine, but will dissolve any foam bits it touches, so you have to be careful.I just bought my 2005 Shadow Sabre 1100, can I clean the air filter or must it be replaced?
Negative to stock or OEM paper filters. Applying oil to those will reduce the air intake causing the carbs to run rich.Does the filter need to be oiled?
