'83 VT750
26,000 miles
I've noticed what seems to be clutch slippage when accelerating at highway speed. For example cruising at 70 when I need to pass so I pin the throttle and the tachometer jumps up 2k RPM almost instantly. Then the tach drops back and gradually climbs as the bike accelerates.
My question is, how can I narrow down the root cause?
From reading Oilology I wonder if the Mobile 1 synthetic oil I'm using is just too slick and causing my clutch to slip. I only have about 1k miles on this oil change so I hate to waste it and change again so soon.
26,000 miles
- worn out clutch
- clutch needs adjustment
- oil
