After checking my switch (2000 Shadow 750 Ace14k) it was gunky so I cleaned it off with a tooth brush & wd40 wiped dry & dab of dialectic grease. When the relay is bypassed the signal lights work like new as well as the switch. Its the relay starting to act crazy it will speed click until you reset it then theres still a delay before the signal flashes. That said I called the local Honda stealer and was quoted 69.99$ before taxes for a new unit. A electrician by trade I know this is a simple relay that can be bypassed with a 3 wire auto tsr as I can not bring myself to pay 75$. My question to the forum is has any one else ventured this route and if so how has the change over held up , parts used etc ? Also are their any threads/links related to this matter as any time saving advice will help my cause. Btw if theres anything ive overlooked by all means holla.
