1 - 17 of 17 Posts
I took bike to local shop to fix the crossover coolant leaking problem.. reasonable price.. but he changed his mind ..his mechanic quit. I have seen the how to video 2 of them matter of fact so I guess I give it a try..how many of you have done this?
1999 Aero 1100
yes, I recommend doing this work yourself. key tools, dental floss and log needle nose pliers. only problem i had was trying to install the wrong o-rings. on the drawing, there's another o-ring near by that I mistakenly ordered. It has a different profile and wouldn't go in. once I had the right o-rings, piece of cake. good luck!
I'm fixing to do that job on my 1100 spirit.
Sent from my LG-H872 using Tapatalk
Discussion Starter #5
One question ...is there any way the tube can slip inside to where you can't get to it?
I don't have that engine but i would do it. Here s a video.
There is another one of the dental floss trick to get the new ring in there.
1999 Aero 1100
no, the tube doesn't fall away. it moves just far enough for the o-ring to get past the gap.
Yes @h13man I read that one before I did mine...
It is NOT too harda job todo...
I used a wire I fashioned hooks onto the end to do mine, insteadda the "Floss String"...
My VT600 was leaking there. I replaced the coolant and oddly the leak stopped by itself. I don't have scientific proof that old coolant causes the leak. More likely the bike was angry at its owner or something like that.
Some coolants used to advertise a small amount of stop leak in them but not sure there is any doing that now.
It isn't hard to do if you watch the videos. It is a two person job, though, After I did my VT1100C i also did my DN-01. It uses the same O-rings and tube. It was 10 years old so I figured that I would just take care of them as well.
The ones I took off the Shadow actually were so brittle that they just fell apart. The ones on the DN-01 were still pliable after 10 years, but starting to get stiff so I am glad that I took care of them.
Just take your time and you will be fine.
IF you ain`t got time for doing the job right now, you might can get some added time, by rotating the tube to resesat the seals...
I noticed my Baby has developed this coolant on the case right below the tube...
It has been many years @ around 50,000 miles IIRC since I did the swap, I`ll give rotating it a try before I commit to doing it again @ 164,540+ miles...
It ain`t hard to do,
D
Discussion Starter #17
OK ..thanks a lot..can't hardly wait to get after it..weather permitting?
1 - 17 of 17 Posts
