Changed the coolant on 2007 vt750 yesterday. (Thanks for all the tips). I did however spill (overfilled) coolant .
After I closed everything up I noticed a drip coming from the bottom corner of the radiator. I never had any leaks prior to this flush so I assume it is from overfilling and the coolant running over and forming in that bottom corner (left side of radiator cover) bike on kickstand leaning in that direction. I still had concern so I checked the radiator cap again and the upper and lower radiator hose for leaks and found none. I then wiped down the lip of the radiator cover real well and took it for a 1/2 hr ride. I could smell antifreeze while I was riding.
I brought it home and put cardboard under and I dont see any leaks.
MY QUESTION IS: If it is only spilled coolant on the outside of the radiator that I am smelling, Shouldnt it burn off pretty quick once the bike is ridden for a while? IF NOT, should I be looking for something else???? Bike never leaked before .
