Ok, I will attempt that. Live in Hawaii so short over priced supply of everythingI recommend the Honda coolant. My bike did the same thing not long ago. The o-ring between the cylinders ended up leaking and needed replaced on mine. That is what caused my coolant to disappear. In my case, aftermarket antifreeze made my waterpump squeal.
So it’s good to add it from that area?I generally buy from HONDA for oil & coolant...
By shopping for cheaper = I find it`s as good a price as trying to "beat the price"...
Yeah BUT make sure it`s aluminum compatible IF you buy from wally world...
I flush coolant every other year,
Dennis
I may do that or just attempt to flush “above my skill level”. It really is lol but gotta learn somehow. Just have to go find a crush washer that will fit and identify the water pump location and drain screw lol.I use Prestone premix due to convenience. However, if your reserve tank is completely empty you should address that. Leak, Overheating? when was the last time it was filled?
I would also add coolant to the radiator but that might be beyond your expertise so you could add to the COOLANT cap but then go for a 10 minute ride and check again. You may have to refill that a few times if the rad is low.
