1 - 9 of 9 Posts
2007 Honda Shadow Spirit VT750C2
Hi all,
I was poking around this morning, took the left side cover off, and noticed a wire coiled and tucked above the tool box that I've never seen before. Is this a battery tender connection? It has a little cap, pics with it on/off. I'm about to get a tender, it'd be sweet if I can hook it to this.
291150
291149
Yes I have one the same way.
The Battery tender junior, and probably others, will plug into it.
Check it first since there should be an in-line fuse for protection, and if it is blown you won't get any charging.
2019 Honda Shadow 750 Aero
There is also a usb connector available to charge your phone.
I tried to send a link but it was linked to my account. Try searching usb connector battery tender..
That is a standard SAE connector and can often be found at automotive/trailer lighting and solar panel places.
Since it is so easily found it also opens lots of possibilities for temporary connection of many things that want 12 Volts as long as the draw is not too much for the aforementioned fuse.
Hi all,
What exactly is it hooked up to?
3004 VT750C
Hi all,
I have the same thing installed on my 05 VT750, use it for batt tender and air pump. I'd say it's time for you to remove the seat, lift the battery cover off and check the connections to battery. These thins tend to have very small guage wires and can fray loose over time.
2007 VT750DC Spirit “chopper”
That’s identical to my battery tender connection, funny enough my Spirit had one on it too when I bought it, went to install the new leads to the battery and there was already one in there... guess that’s a good sign from the prior owner?
Same here, came with my trickle charger. I believe too, like longbeachgary1 said there is a USB connector available for that. I want to be able to use my phone as a gps if needed and plan on getting the USB connection as soon as I can find a decent phone holder.
1 - 9 of 9 Posts
