The bike has been difficult to push from a stand still and I've noticed friction and noise from the front of the bike, so today I looked at the front brakes. Replaced brake fluid by bleeding them, and then set out to remove brake pads to take a look at them.
I could not hand depress the pistons and couldn't get the brake pads off without removing the calipers. 1. Safe assumption that this being frozen caused the calipers to constantly press the brake pads against the rotor slightly, making the bike difficult to push?
Started cleaning the calipers with brake cleaner, and to see how well the work, I used the brake lever to move them. See picture. I noticed that only the one on the left moved up and down. 2. Does this mean there is something wrong with the one on the right?
In my distraction to attempt to get the one on the left to move, I continued to press the handle until the one on the left blew out. DOH. I put it back in with the help of a c-clamp. 3. I take it there is air in here now and the fluid needs to be bled?
I pushed them both flush with the caliper to more easily clean everything. Now I still can't get the one on the right to move up any.
Already ordered factory pads to put in.
4. Do I need to rebuild the caliper? The caliper currently does not leak. I found seals, do I need new pistons? Not sure how much they are corroded and can't easily clean them without taking them off. Is this a difficult procedure?
