When my chains are a little on the tighter side they dont stretch as much, but you dont want to make them tight. as you lock out the rear suspension, that swingarm needs that free play to be able to move up and down properly and freely. and you can cause increased wear of the sprockets, output shaft bearing, rear axle bearings. so once again LOOSE LIVES.Thanks again I'll take it to the end, maybe I'm giving to much off the line and streching it, is that possible?
It there to tell you that you have reached the service life of the chain. AND that if you don't start arranging replacement, you are soon to be pushing the bike home. Soon is a relative term 0-6000 miles.Why is the Warning mark there when there is three more lines to go. Is it alright to take it to the End?
