1 - 16 of 16 Posts
2006 Honda Shadow Spirit VT750DC
I have a 06 vt750dc. I am changing out the stator and lost the washer that goes with the clip on the top of the drive sprocket cover. Does anyone know what size this washer is so I can run to the hardware store and look for one?
It is #5 in the picture
Font Art Pattern Book Diagram
2006 Honda VT750DCB A/A WATER PUMP | Ron Ayers
Here, it says:
#17
WASHER (9.5MM)
90504-MAH-000
So that is about 3/8" (9.5mm = 0.374")
The outside diameter (OD) could be smaller than an SAE washer and should be about the same as the rubber cushion in the assembly.
Most hardware stores have assortments where you can find that washer, I'm sure.
jmo,
Happy Wrencher Now ! ! !
Lets RIDE,
Dennis
Sunset Cruise upcoming...
Gotta check out my new LED Headlight
As I read instructions, I see it is adjustable which Hi / Lo shines where in the optics of the headlight lens ...
I`ll see which is best,
Dennis
Thanks for the reply guys! I was looking on partzilla and it never occured to me to look under water pump section.
Appreciate it!
Thanks for reading my post...
That's why I like Ron Ayers over Partzilla, Ron shows little schematics of the parts, not just words for every section.
That part number in post #3 is a link to the washer at Ron Ayers.
jmo,
1 - 16 of 16 Posts
