The stock head light on the Aero sucks to the point that I have to ride with my high beams on or risk not seeing things in the road until it is too late to avoid them. Light bars are way overpriced for what you're buying, so I'm looking to add my own lighting setup. I like the placement on either side of the headlight and now see why memphis shades wind shields cause such a problem. Luckily, I think I'll actually be able to make mine work for me.
Here are the lights I've bought. Too bad I didn't get a phantom, as the black finish would fit nicely.
$12 from Northern Tool and Equipment. $5 off coupon and I'm out for $8 and change.
This is about where I'm planning for them to be.
Depending on how the brackets work out, the lights should be just about flush with the headlight, front to back. Maybe a little forward, but I'm going to keep them mounted as far back as possible without actually contacting the windshield. The box does not specify, but I'm fairly certain they have 55 watt bulbs, which I'm going to replace with something that draws a little less power. Does anyone know if there is an LED bulb that could fit into this style housing?
