1 - 3 of 3 Posts
1998 Shadow ACE
When I hit bumps engine cuts out for a second. After 3 or 4 the 20 amp fuse blows. Any thoughts
Check the connections at the battery.
Sitting on my VTX making Vroom Vroom noises.
The main fuse is usually 30 amps. But still you need to find a shorted wire. Maybe under the tank. Check the grounds at the frame and engine . Look for added wiring from the battery to accessories.
With it running twist the bars. Sit on the seat and bounce up and down. Twist the tank on it's mounts. Pull at harnesses.
1 - 3 of 3 Posts
