In my area Prestone comes in two flavors: the Yellow bottle containing green fluid (Extended Life full compatible) and the silver bottle Dex-Cool. Both label claims are clipped below and they both say they are okay with aluminum. So either choice is fine by me. I never buy pre-diluted stuff since you can just do the math, there is a huge markup for the added water. This being said, be sure to use distilled water, NOT tap or bottled water, as those minerals are more harmful to your bike than anything else. Pure distilled water is at any grocery store.
In direct reply to your query, neither of the Prestone products below contain any silicate corrosion inhibitors as contraindicated by Honda.
Prestone® Extended Life Antifreeze/Coolant is compatible with ANY antifreeze/ coolant – regardless of color – for use in ALL makes and models of cars and light duty trucks. This patented formula provides a high degree of performance durability and carefully balanced protection against temperature extremes and rust corrosion of all cooling system metals, including aluminum.
Prestone® Dex-Cool® Extended Life Antifreeze/Coolant is recommended and formulated for use in all vehicles that require DEX-COOL® coolant, as well as all other cars and light duty trucks with aluminum radiators using extended life coolant. This patented formula has a concentrated blend of premium long-lasting inhibitors for extended performance, protecting against temperature extremes and the ravages of rust and corrosion for 5 years or 150,000 miles.
