Clymer advises removal of starter motor, alternator, clutch, and (of course) both engine cases before the engine is removed. Considering the engine slides out the left side (after sub-frame is removed), I don't see why these parts need to come off, except for weight reduction.
I have a motorcycle jack that I will position under the engine before I disconnect it from the frame. Weight is not a huge problem.
Any advice?
The only thing I don't see an answer for, is the wire from the pulse generators: do not see any connector at the engine or the steering head. Does this wire have a disconnect, or does the left side engine case have to be removed and stay with the frame?
Any advice?
