From your description it sounds like re-jetting the carbs would be in order. You can contact Vance & Hines on their support page and I would think they would have a recommendation on what jet kit to use. Probably a good time to give the carbs a good cleaning while they're off as well.
Synchronizing your carbs is fairly simple. The Honda shop manual will give you detailed instructions. (You can also do a bench sync while the carbs are off which will get them working really close.)
