WMU_BRONCO said:
How do you remove the breather cap on the final drive? Is it pressed on or screwed on?
Hey Bronco,
I am assuming you want to either check the level or add level to your final drive unit?
As bullzeyet said...it doesn't remove easily. Most people that have removed them have damaged them beyond use.
To check the level, with the bike on the side stand, remove the upper plug (the larger diameter plug in the side of the case). The oil level should be equal to the opening. None should leak out though.
To add, through this same opening, fill until it is just below the opening while on the side stand.
To drain, remove the lower plug and allow the oil to drain. Then replace the lower plug and fill through the upper plug.
Hope this helps.
Joe
P.S. Here is the microfishe page for the final drive unit.
http://www.ronayers.com/fiche/200_0...en_gear.cfm?man=ho&groupid=12740&parent=12650
