So with a lot of thanks to this forum, my '85 Shadow was started for the first time in about 11-12 yrs. I ended up buying a completely rebuilt carburetor set. The one I took off of mine will need some repair work as well as a full rebuild. I'll do that eventually to that one, and keep it as a spare. Now though, the bike starts right up without too much hassle. Still haven't taken it on the road yet though. Still some things to do. The next step is changing the coolant and oil/filter. Have to figure out the starting issue too. The button itsself is cracked. And, when I press it, there is usually a delay in the bike turning over. Sometimes its just a second..other times I'll have to release the button and then try again. I have a new solenoid on the way...hopefully that's the issue. New front brake light switch coming as well. Already replaced the front pads and fluid as well as the clutch fluid. Once she's on the road, the tires will be changed for new, and I'll have the shop replace the fork seals at the same time as mine are leaking. But, its getting closer to being back on the road! With still less than 20,000 original miles it should be a nice little cruiser if all the little things can be taken care of.
The last time I tried to post a picture, they were doubled for some reason. I'll try to get a few posted here soon.
