1 - 11 of 11 Posts
Discussion Starter · #9 ·
Thanks all! I will be looking for a new part just to be safe. It seems to sit too vertical. Even with the new part would it be possible to put the actual pedal on a closer level to the peg (less vertical, more horizontal)?
The Pedal attaches to a threaded rod that runs under the bike. It has adjustment at both ends which will let you rotate the pedal the pivot. Shortening the rod by turning the bolts will rotate the pedal forward, effectively lowering it and moving it further away from the rider. I can take a pic of mine tomorrow if that would help.
1 - 11 of 11 Posts
