I did a search and found this thread from 2007:
http://www.hondashadow.net/forum/72-technical-discussion/49857-front-brake-pulsing.html
It sounds almost identical to what I experienced today. Braking a slower speeds, all is well. Braking from higher speeds and the front end pulses, literally moving up and down as she slows.
The posters on the thread recommend
1) cleaning the brake assembly,
2) checking the rotor for warping
and, from another thread of the same era, ( http://www.hondashadow.net/forum/72...ront-brake-has-pulsing-grab-when-applied.html )
3) check that the caliper is mounted securely
4) check for a loose connection in the triple tree (though as a greenhorn I have not idea what that is...)
Is this the list, in an appropriate order, that I should be working through?
All has been well until today in which she spent more time in the sun. Could the heat play a factor and/or the brake fluid level? There's only the tiniest of bubbles in the reserve tank.
Anything else that might be likely I should look into?
Thanks. I'll be a grease monkey eventually. It would make my dad very proud...
