1 - 6 of 6 Posts
need a memory refresher .
fuel mix : out = richer
in = lean ?
air mix : out = more
in = less ?
stock setting = 2 1/2 turns on both?
mine: [email protected] pipes with baffles in
3 turns both A/F
still bad popping on decelelartion
exghaust manifold bolts tight n dry
carbs nice n clean
seafoam made no diff...
There is either a fuel mixture screw or air mix screw on carbs, but on these CV carbs it is a fuel mixture screw. Out= Rich
Aftermarket pipes with no crossover connector will pop a lot more than a factory muffler with a crossover.
Discussion Starter #3
j​
i have 2 mixture screws per carb on mine..one is close to cylinder ..other is closet to air box intake boot...
Sorry I never heard of that set up. Did you say which bike you have?
Usually there is only one low speed mixture adjustment .
There are several screws exposed however .
1 is the mixture screw
2 is the float bowl drain screw.
3 is the vacuum port to sync the carbs.
Besides the big plastic knob for idle speed.
Discussion Starter #5
86 1100 vtc... no sir the bowl drain screws are below both bowlls...i failed to mention the brass plugs have been drilled out exposeing the adj. screws
1 - 6 of 6 Posts
