1 - 2 of 2 Posts
I have a 1986 shadow vt1100. When I accelerate hard, my fuel pump will flutter like it isn't getting any fuel. However, my bike does not act like it's not getting enough fuel. I can just put my hand down on the fuel pump and feel it pumping really fast. I removed the fuel cut-off relay and hot wired the pump into the relay circuit because the relay went bad. The fuel pump always kicks on when I turn on the ignition and fills the carbs up, but then stops like normal when the carbs are full. Any help would be greatly appreciated!
my guess.
hard acceleration drains the fuel bowls.
the pump runs to fill them back up.
that fluttering is simply the normal feeling of a pump diaphragm doing its job.
want a test to prove it?
pull the hose off the "out" port.
connect a hose to a fuel can
jump the battery to the fuel pump and let it run into the fuel can.
does it feel the same?
is it pumping fine?
1 - 2 of 2 Posts
