hey on my 85 shadow 700 i cleaned the carbs today after running out of gas (long story) all was clean inside
my fuel pump however....
if i use a jumper wire siright to the battery fuel will shoot out strong but without the jumper wire with the bike in the "run" position while pressing the starter button i get no gas shooting out.
i used a test light on the pos wire going to the pump and when i switch to run it will turn on for a few seconds then go out, then when cranking it will flash (dim light) but as soon as i stop cranking it goes out....any ideas?
is there a relay? if so i couldnt find it anywhere under the seat....does it look like a typical square automotive relay?
sorry about the long post, thanks for your help
