1 - 3 of 3 Posts
I just changed my fuel pump but it still isn’t starting do I have to prime the bowls or something? Thank you
Is your fuel relay good? The fuel relay controls the fuel pump. You can simply bypass the fuel relay by temporarily re-routing A to B. Then if the fuel pump starts working, the relay was bad. Btw, how did you determine your old fuel pump was bad?
283965
1 - 3 of 3 Posts
