Welded tabs to my crash bar to mount my new LED auxiliary lights BUT now if they are wired to my headlight I get a choice,on with high beams OR on with low beams.What you think??(Or just wire direct power/ground/toggle??)
With using the headlight as a trigger with it comes down to do you want them on high beam or low beam trigger and the ability to do this legally may have local rules to follow, the headlight is on all the time but it may be the high or low circuit that is activated.They should not be wired direct to your headlight. The headlight power goes through a contact in the start switch that isn't rated for that much current. I would wire them through a relay powered from the battery and enabled by the headlight.
