1 - 15 of 15 Posts
1995 VT1100C2
I would clean the entire area to try to locate that leak. It looks like spray so could be anything. If a mechanic did the oil change, take the bike back to them.
Discussion Starter · #3 ·
I did that before.
I cant detect where the leak is at
Any help how can i detect it
Wash it off and dry it and throw some baby power on the area .
Ride and keep checking for a brown stain in the power, that is the source.
It does look like spray in the second picture, are you losing coolant from the radiator area?
1995 VT1100C2
The fins look dirty so clean them off. You may have a head gasket failure but I agree with swifty: spray from coolant hose or just something from road.
The spray pattern appears to be something that sprayed into that area from some kind of road debri not coolant or oil.
Discussion Starter · #8 ·
Does the bike have too much oil like this?
Could this be the reason that the leak happened?
To check the oil properly, straight up and don't screw it in to dip/check.
Discussion Starter · #10 ·
Did that and checked it 2 times its overfilled..
The mechanic actually put 3 liters and i think the manual said 2.6 liters
Please correct me if i am wrong
2001 Shadow Spirit 750
My neighbor had a big yamaha that suddenly developed a leak around some O rings near the head. Bought new O rings but still leaked. Asked about what was done recent and it had been to a dealer for service that included oil change. We drained the oil and refilled with the proper amount...no more leak. I was told that too much oil will find a way out. Could be your case also.
'94 VT1100C
2.6 litres = ±2 ¾ US Quart
1 - 15 of 15 Posts
