1 - 10 of 10 Posts
Hey guys,
First I want to say that English is not my first language, and I apolagise in advance if I make some technical mistakes explaining my problem.
Recently I bought a Honda Shadow 600vt year 1995 for a Bobber project.
The only problem that I cannot find a solution for, is that one of the rubber tampons, which is bellow the hangers of the handlebar is totally ripped. I am attaching a picture as well.
This makes the handlebar really floppy, and all the vibrations go directly trough it which has resulted in creating some small cracks in its base. I am going to change the stock handlebars anyway, but I cannot find such tampons anywhere.
Do you have any ideas how I can fix/substitute it?
Best regards,
Asparuh
292542
Discussion Starter #3
Thank you for the reply!
Unfortunately I do not see what I need from this list.
2003 VT1100C Spirit
Howdy Asparuh!
Hope we get to see some pics of your Bobber project...
Welcome to the forum.
We refer to those rubber parts as riser bushings.
I don't why they are so hard to locate. Factory installed press fit I guess.
There was a thread here where a guy made different ones for his bike.
You may have to do something similar.
Reactions: KC_97Shadow1100C
The bushings are not available separately. Assuming they are the same as the 1100, they are 4 separate bushings with steel sleeves on inside and outside., bushings pressed in. There is a machined ridge in the center they seat against, so they cannot be driven out through the top bridge. Makes removal a real chore.
As for the urethane, one might be able to buy urethane round stock and machine 4 new ones.
Discussion Starter #9
Hey Guys,
Sorry for the late reply, and thank you all for the provided answers! I will go with the urethane solution with this problem, and will keep you updated what happened.
Meanwhile I am attaching a picture of one of my previous Bobber projects. The Shadow will come out even better! This is a Honda Rebel 125:
292565
1 - 10 of 10 Posts
