1 - 5 of 5 Posts
Hello there! I'm new here and i have a question.
I have a VT750 spirit 2001, and i recently put new turn signals (both front and rear) and did the wiring. I'm also putting a new speedometer (drag specialities mini electronic speedo) and when i did the wiring of the speedo i heard a "click/pop" noise comming from under the seat. Then the headlight stopped working, both hi/lo beam. I check the bulb, the fuse, etc. and i had to change the 10A ignition fuse. Still no headlight. What can it be?
thanks!
Do a continuity test on your fuses. They can burn and still look good. Also, check your 30 amp main.
Discussion Starter #3
I've change every fuse. But the 30 main, woundn't the bike won't start if it went bad? The bike crank and everything. Just the headlight that doesn't.
I everything is working except the headlight. it my be start switch contacts.
Reactions: CSRoad
1 - 5 of 5 Posts
