1 - 12 of 12 Posts
What is the best options for brighter lights?
I have read a couple threads that the LED bulbs don’t have good high beam spectrum which has me skeptical. I would like to find a brighter light that performs well in factory housing if possible. Im also considering replacing the entire fixture but unsure of what options are available that will,
1) be able to hold the wiring like the stock housing, and 2) mounts where the stock housing mounts (I do understand modifications may be required.)
Would gladly appreciate any links, photos or info to what you all run and have had the best performance with!
2001 Valkyrie I/S
I'm sure there will be some different opinions on this but here is mine. Some LED bulbs don't work well with the reflector and lens because the reflectors are made for a incandescent bulb and they reflect light differently. I would either up grade to a Sylvania silver star bulb or go with something like this.
You would have to modify the mount for it to fit the bucket or buy a Harley bucket and fit that to your ride.
Reactions: Austinlindsey1
Mine too, exactly what Punxsy said. And I'd add do it on a deserted flat road with you or someone the same height/weight sitting on the bike in your lane. Aim it so the high beam bright spot is centered in your lane and as far down the road as possible without lifting the spot off the pavement. Found my last 3 bikes came with the high beam hitting the road 50 to 100 feet out, aimed WAY too low from the factory.
2003 VT1100C Spirit
Howdy Austinlindsey1!
I replaced the standard Halogen H4 headlight bulbs with plug and play LED's on both the Spirit and my Valkyrie. These LED's were inexpensive finds off of Amazon. The "mystery" manufacturer claimed a 30,000 hour bulb life with a color temperature of 6000˚K. Both bulbs have worked great since August 2021.
I did do some testing when I replaced the Halogen headlight bulb on the Valkyrie...
The headlight was on high beam for both Halogen and LED bulbs. My incident light meter was set 10ft from of the front of the headlight in the middle of the beam. The bike was up on my lift and the front wheel was held steady by a wheel chock.
Halogen Headlight Bulb: 156 foot candles, with a color temp of 2800˚K (about the same color as a standard incandescent household bulb)
LED Headlight Bulb: 356 foot candles, with a color temp of 7000˚K (about the same color as an overcast day outside)
Simple math yields that the LED is more that 2.28 stops brighter than the Halogen bulb. Since one stop of light increase means double the amount of light, the LED is more than 4.5 times brighter than the standard Halogen headlight bulb.
Not bad for a $30 investment!
2008 Honda Shadow Aero 750
1 - 12 of 12 Posts
