But many guys here have put a tach on their bikes and I never heard of an electrical blow up.
Not sure how it is protected.
Maybe the tacho inputs are just well protected? Seems like even old school 12V points systems were dealing with a lot higher transient voltage pulses than 12V because of the inductive spike.
I recall looking at the primary signal when I was trying to figure out the fuel pump "relay" on my 1100. The pulse amplitude was high (negative), but the spike was very short, it wasn't a whole lot of energy.
Then there is an optocoupler used that I thought was used to isolate the ignition circuit from the controller. That optocoupler diagram had me confused with motorcycle ground connected to the cathode then a "Negative" coil wire connected to the anode...
The forward voltage through that optocoupler diode is just 1 volt
The person who made this originally ditched the optocoupler because the truck had a tach output on the ECM and it was direct connection to the controller. now ill be looking for a pinout
maybe its just the resistor saves the day
My understanding of optocoupler is that it decouples the circuit from the input by interposing an LED driving a phototransistor. Like this:
The input signal lights the LED, and the max amplitude that the phototransistor will deliver is dependent on the right side power supply voltage, not the input signal.
What you drew was equivalent to just the left side, input side of this sample circuit. The LED is a diode, so would have a fixed voltage drop, 0.70V commonly. In series with the 10K resistor, all the voltage except that 0.70 V would appear across the resistor.
I understand enough about electronics to make stuff work, but I also occasionally let the smoke out, so please be careful with my advice, as you hopefully would with any free advice found on the internet.
Having said that, here's another idea. I think that the fuel pump supply wire from the fuel pump "relay" that oldguy mentioned, is essentially what one might want to drive a tacho. That gadget sends a fat 12v pulse to the fuel pump every time the (front?) cylinder fires. It takes care of buffering the high amplitude negative spikes that the coils like, and you wouldn't be parasiting any power from the ignition circuit.
